RocketTier
- Aug 2, 2022
- 4
Hello, all. I am new to posting, but have been lurking for a while.
Issue: Repeatedly tripping a GFCI outlet once I pass ~600w of power draw on a small(ish) semi-DIY solar gen. Unsure if it is a G-N bond issue, but am more concerned that I have an actual current difference between the neutral and hot legs caused by a short somewhere in my system.
Background: I recently put together a 48v solar generator/backup system, closely following many of Will's videos, as well as many of the discussions spread throughout these forums. I am using an EG4 6500ex, and a single 48v EG4-LL (V1) battery. I have a PV DC-isolator in between the all-in-one and my main PV line, and have wired the AC output to a 20Amp GFCI outlet as I felt uneasy just using a 14ga extension cord. I've been in construction for years and have done plenty of small repairs and DIY electrical work, but I am still definitely a beginner with all of this and am honestly pretty nervous about working with electricity on something that depends on so much of my own work and on connections that I can't visibly see (the ones enclosed in the 6500), so I have been slowly increasing the amount of solar input and AC output as I test the setup. I got up to 900w/~160vOC of PV input, and that has been charging the system great and with no faults showing in the 6500 itself. However, whenever I attempt to draw more than about 600w of power (it varies each time, that has just been the average), the GFCI outlet trips within seconds.
I have the older 6500ex from before the N-G bonding issue was remedied, and to be honest, I still don't fully understand the issue even though I have watched videos on it and have read threads here discussing it. I thought my setup was small and simple enough to not run into problems with it, but I'm hoping it really is related to that and not something more dangerous/concerning.
I'm sure I have used incorrect terminology in this post in my ignorance, so please go easy on me but I welcome and appreciate corrections and guidance and any requests for more details.
EDIT: I may just be stupid for using a GFCI outlet and should just opt for using a 12ga extension cord, but I just don't see why I would be having this issue unless I have a more serious problem that I just don't understand and need to address. But again, ignorance.
