Theyre the standard balance cables that were provided, about 25cmDo you have especially long or low gauge cell sensing wires? If so the voltage drop from the BMS power consumption would create an offset on whatever wires see the current.
Revelation time
I just had a thought, as i'm powering the BMS from the battery pack itself, it also has the option to use an external DC power supply with a little toggle switch. although completely impractical for my use, ive run an extension cord outside to my battery box, pluged in a 12v wall adapter and changed the switch from internal power to external on the BMS. Instantly all voltages now read correctly within 5mv of each other on the BMS display
No idea why or how or what but its working.
Again I cant use this setup full time as my battery box is outside with no easy mains power access, so I think based on that alone they will have to go back to chargery, this is either a massive oversight on their part hence why some people don't see any issues and some do.
Anyone else confirm this for me?
@shavermcspud Have you tested to see if there any change if you unplug the relay outputs from the Chargery ... using internal power?
The cell voltage accuracy on my 4S pack seem to be fine whether powered externally or externally ... but right now I am using relays with a low current draw.
It seems pretty odd that the larger pack would be the one to have problems when internally powered ... I sure would have predicted the opposite.
Really glad you thought to troubleshoot with an external power supply. Sometimes the process of elimination works in spite of the fact it doesn't seem likely.
It is the BMS8T.What BMS are you using? is it the smaller chargery version?
Well it all turned to utter sh1t last night.
Got up this morning, neither the BMs cut off or the inverter low voltage disconnect at 48v two cells down to 2.1v. I give up.
Jesus, you are having a run of really poor luck, I'm sorry your having such a poor experience.
Have you
(1) Made sure this is actually the case with a multimeter
(2) Charged the cells back up to a normal levels (I vaguely recall you want to charge slowly to recover from under voltage, but I may be mistaken)
Yep both read exactly the same as the BMS for a change, ive put the two cells on my Lifepo active model balancer and bringing them to 3.2v at 2amp they seem to have recovered but what damage has been done i dont know.
I have some top balanced Senberry LF280 cells here in Florida. If you decide you need some right away I can send you some of mine. My project is moving at a snails pace and I have more coming.I honestly give up now
