lynx3ffect
- Apr 26, 2022
- 2
Hi all,
New to the group. I've in the process of deciding where to put my shunt. I have a separate port BMS with the extra negative charge cable. All setups i've seen show the BMS attached to the P- cable, after the BMS. However, I can't seem to find the correct position for a separate port BMS. I've seen a few set ups with the shunt before the BMS, but i'm aware that the BMS low voltage won't active in this arrangement. Without buying a common port BMS, is there a suitable solution?
Regards,
AT
Regards,
AT
