Ok, hope I'm posting this in the correct forum. I have an EG4 3000EHV-48 that I have been successfully using with a JK BT 8S-20S 120A through Solar Assistant. Recently I purchased two Seplos Mason v3.0 kits (48v) w/ active balance to replace the single JK.
I am banging my head against the wall trying to get the Seplos v3 to connect to Solar Assistant. I have used the Seplos adapter to connect to the Seplos 3.0 with my PC and update the firmware. But every attempt to connect it to Solar Assistant fails. I tried the Seplos adapter, I also bought a USB to RS485 adapter to make my own cable according to the pin out in the Seplos manual.
![1000013082.png 1000013082.png](https://diysolarforum.com/data/attachments/221/221149-69824369d96d9e1c77f3ff14ce1d0ddf.jpg)
I'm using this adapter:
![1000013076.png 1000013076.png](https://diysolarforum.com/data/attachments/221/221151-fcd0586707da4f7260c90ccc878d79eb.jpg)
I emailed solar assistant for support, they said to select USB modbus for the battery. That has not changed anything. I get a "no response" message when trying to connect to the BMS. I have all dip switches off and the comm cable is in the left port for CAN/RS485. It does the same "no response" message when I use the middle port too.
![1000013083.png 1000013083.png](https://diysolarforum.com/data/attachments/221/221156-1e970a749b04c810d6a1d5373796e4be.jpg)
Does anyone have experience getting The Seplos v3 to talk to solar assistant? How about just getting the Seplos v3 to talk straight to the 3000EHV-48? Can I just run a straight through Ethernet cable between the Seplos v3 and the 3000EHV-48 and select Pylon as the protocol on both?
