That is how I believe Tigo optimizers work (use the bypass diodes on the back of the panel).True. Which runs counter to harvesting the most power. I think each optimizer should draw down panel voltage to activate bypass diode for a shaded section, including for some half-cut panels.
The point is, it that is what they do (and they don’t integrate their own more robust circuitry to bypass an entire panel), then it doesn’t change anything as far as the eventual burning out of a bypass diode in the presence of severe partial shading and the eventual burning out of the panel after that…
If they can safely bypass an entire panel then they would at least be able to protect a partially-shaded panel from damage (even if leaving a bit of potential power output on the table) while still being able to maximize output for partial shading which less severely chokes-off current as well as compensating for mismatched panels, mismatched string length, etc…
