The Good Package
If you already have shaded panels, adding more panels just equates out to more shaded panels and no gains.
If you have everything under one SCC. Some of us are paranoid about redundancy and use multiple.
What do you mean by 2.0?
Oh that's the worst problem in my opinion. I want to kill myself when I make the same video a second time ? I need to keep progressing to better equipment with more features. Not stuck on topics that I've made multiple videos on. I don't know how many times I can repeat myself. I feel like a broken record at times.Sounds like you have enough 2.0 content lined up for a while. Not a bad problem to have as a creator...
This issue is only present for about an hour and the output during this time is awful. I would have to chop down a wall and livestock shade. Absolutely not worth it at all. I just add more panels and capture more when the sun is overhead. I do not want to tear down my backyard for low angled sun. Not worth it at all.You could however arrange those strings such that the bottom half of one of the strings is shaded and you'd get much better results even under shading conditions due to that modules design (forget the term, split cell?)
A high voltage with low current suggests to me that the shading causes a high resistance. (Ohms law and all that)I find it odd that voltage can be that high and the current is just awful.
Oh.. sorry! I thought you put them there just to demonstrate shading issues (hence my jovial first reply) !! ?... I would have to chop down a wall and livestock shade. Absolutely not worth it at all...
No. Fun. ?I do not want to tear down my backyard for low angled sun.
FWIW, I watch a (successful) Youtube channel periodically that has updates twice a week and often hits the same topics over and over again. The reality is that "current" is more useful for people to find things than older content that does deep dives. It is less like a book and more like a newspaper.Oh that's the worst problem in my opinion. I want to kill myself when I make the same video a second time ? I need to keep progressing to better equipment with more features. Not stuck on topics that I've made multiple videos on. I don't know how many times I can repeat myself. I feel like a broken record at times.
I changed my panels from series to parallel strings originally to avoid frying my AIO inverter charge controller as the temps got close to freezing in the fall. I realized the additional benefit when my production jumped way up even on partly cloudy days. Partial shading was killing my output previously.
I've covered this before actually. People don't want my older videos sadly. People keep requesting me make videos I've already made and it's driving me bananas lol
err... see post #18What is the system voltage, what VOC are you operating at, and what kind of panels are you using?
Would be nice for someone to post their evidence of series string being better than parallel configuration for shading. Please challenge my position! I have done this test many times now and the results are the same everytime. I even covered this in older solar panel test videos. Same results, every time.
Absolutely. In my book I have a configuration that is series and parallel, so there is still some benefit of mppt, less copper, and still running at a relatively safe voltage for beginners. And parallel strings enable people to configure panels around things that like to shade panels on the roof of RVs, such as air conditioner units.Only downside I see to paralleling panels is cost. Wire, fuses, controllers. Hidden benefit, you can keep it safer voltage wise.
I need to make a video about this. I cleaned my 16.3 kW array a couple months ago and the increase was insignificant. It really depends on what type of dust or pollen is in your area. Some place is need a lot of cleaning on their panels. Out here in Vegas, it doesn't make that big of a difference. I do like to clean them for the videos though.Looks like some of your panels could do with a bit of cleaning. Time for the hose and long handled squeegee.
I need to make a video about this. I cleaned my 16.3 kW array a couple months ago in the increase was insignificant. It really depends on what type of dust or pollen is in your area. Some place is need a lot of cleaning on their panels. Out here in Vegas, it doesn't make that big of a difference. I do like to clean them for the videos though.
