Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,690
Just to add to this, I have created a universal string sizing tool that will work with GT inverters and Charge Controllers. You can string size with any inverter or charge controller type.
string-sizing
Feedback on your sizing tool:
It appears to make recommendation based on STC rating of panel, not PTC, so it undersizes the array.
I entered a "custom" inverter for 10,000W (because you only have a couple recent models ready-made.)
I selected SunPower E20 327W from your list.
The tool recommended 7s4p. When I pumped it up to 8s4p, it said,
"10464, Over the Inverter Max Power of 10.00kW with Oversize Factor of 1, Max Should be: 10.00 kW, You have 10.46 kW"
That's only 4% over, and based on STC ratings which of course are rarely achieved.
Your tool ought to use PTC ratings to suggest an array which drives the inverter to full power.
Given voltage and short-circuit current limits, you could also recommend a maximum over-paneled configuration.
We often consider that to get additional power off-season and longer in the day.
Many people have non-ideal orientation. In that case you could recommend a larger array to still reach maximum output.
And finally, some of us use multiple orientations of strings, wired in parallel (or into multiple MPPT) for "passive tracking".
