Setting parameter settings for 2 12v batteries in series to a 24v hybrid inverter/charger
Mjr
Hi, I have just purchased a Hybrid LV2424. I have two 12volt 200 amp hour lithium batteries that I plan on putting in series to make 24v. My questions is setting the parameter settings on the Hybrid unit. I know I have documentation on the the 12 volt batteries for what parameter settings to do. Since I am putting the batteries in series do I double the parameter settings?
Thanks
2X 12V voltage settings
Current and capacity ratings are the same.
MAKE SURE YOU FULLY CHARGE EACH 12V TO FULL INDIVIDUALLY AND THEN IN PARALLEL BEFORE CONNECTING IN SERIES.
