Ha ha is it a major concern or just a question ?To reiterate, since SHADING is a major concern, parallel is your best option.
If solar panels are subjected to partial shade on different panels throughout the day is it better to have them connected in parallel or series? Which will lose the least amount of energy to the SCC?
In the real world I think they help a bit but at the end of the day shade is bad for solar and you are best off avoiding it if you possibly canDoesn't the use of bypass diodes reduce the problem of having a panel shaded when connected in series?
Sorry to bring this back from the dead, but I want a clearer answer to this question myself. I'm finding on multiple websites (including here) that in a series configuration, shading one panel drops the output of the other panels as well. In practice, this is not what I am seeing. I have 3x100W solar panels for a 12V system using a Victron MPPT controller. When shading one panel, the MPPT controller reduces the voltage and I am left with full output from the other 2 panels. Would it be any better in a parallel configuration?
What you are seeing is the action of the bypass diodes. For controlled situations like you describe where notable shading takes out a significant portion of the panel, they work very well. Partial and variable shading can yield erratic results. Performance is also a function of the quality of the MPPT algorithm.
Example:
3 100V panels
Panels 1 and 2 can output 6A, but partial shading reduces #3 to 2A.
In the series config, there are two choices:
1) maintain voltage and reduce current to 2A for all three panels
2) cut the underperforming portions of the panel out of the circuit by reducing voltage and allowing 6A to flow from unshaded/partially shaded panels.
In the 3P config, you'd get 6A/Vmp from the two unshaded panels AND 2A/Vmp from the shaded panel.
Awesome thank you! So with your 3 example panels where 1 is shaded and 2 are in full sun, you would get:
In series:
Either 2A * 300V = 600W, or 6A * 200V = 1200W.
In parallel:
(6A * 200V) + (2A * 100V) = 1400W.
Is that correct? That is assuming that partial shading would still result in 1/3 power coming out of the solar panel. From what I've seen with my small 12V 100W panels is that covering just one cell reduces power to 10%.
