bluecolumbia
hello
i've got a newish installation on my sailboat, 12v, 380ah of lipo, 680w of solar, charging from 170amp alternator w/ external regulator), all works great. but i'm currently limited to a 20amp charger at the dock (just using the charger that came with the batteries), so if i come in to the slip with low batteries they charge very slowly on shore power. (especially since there is a constant load of 10-20 amps running). so i'd like to add a 100amp ac-dc charger for shore power.
i already have all of the inverter power i need, so i would not benefit from getting a charger/inverter combined unit.
i see that there is an extreme range of prices for ac/dc chargers, and i don't understand why. i'm looking at a <$200 charger intended for an rv, which appears to have the same features that the more expensive marine chargers have. equivalent marine chargers are 10x to 20x as much. (yes i understand the marine markup, just trying to understand if i'm missing something else here). all of the systems i'm looking at have a mode for lipo batteries.
2nd question - what i really want is a device that will charge the batteries, and isolate the batteries, and provide 12v power for the house while connected to shore power (and then connect the batteries to load when shower power is removed). it seems like the large superyacht/industrial systems do this, but it doesn't appear that even the more expensive marine systems do this at the size i need. do any of you isolate your batteries while on shore power (so that they are not running loads at the dock and constantly cycling)? i could accomplish this with some switches, but it seems like this would be a logical feature for a battery charger.
thank you for any advice
...bluecolumbia
...bluecolumbia
