I need a new bank of lifepo, I was considering to buy Winston cells from gwl but recently I found those ones : https://www.gobelpower.com/eu-stock-eve-32v-280ah-rechargeable-lifepo4-battery-cell_p95.html#1
They seem grade and at 1 discharge and 2 peak they should be able to run my motors for short term 1 Motor is 1 kw and run for about 10 min, the other is 3 kw with a max runtime 2 min .
I wonder if it worth to buy 4 or even 8 b grade eves over the Winston cells and get more capacity ?
Should I expect 2000 cycles from those cells ?
The motors will be connected directly on the cells and a BMS will control a remote switch and the charge - balance .
What do you think ? Am I expecting too much ?
