jfrasier71
- Jan 23, 2022
- 14
So a couple months ago, I installed my first system in my RV (with great help from the community btw)
diysolarforum.com
Currently, I have a series connection, and am only outputting around 80v and 1.6a on a good day from 2 200w panels. I suspect that is because I am in series, and it is causing a loss due to one of the panels being shaded. I am planning on switching to parallel so that each panel will work on its own. But that will lead to more heat in my wiring. ATM, I am using 12g solar panel wiring, around 13 ft of it. I looked at the chart, and it looked like it would be ok, but should I change that to a thicker gauge to compensate for the heat, maybe 10g or should I be ok with the 12g?
![diysolarforum.com](https://www.mobile-solarpower.com/uploads/1/2/9/6/12964626/img-20190331-124124-456_1_orig.jpg)
OK need a little help with my first system
Ok been following solar and your videos, but I think I may have borked it. I am moving into my RV for a while, and I work on my computer alot. So I wanted to set up an independent system just to run my desktop computer, my cellular modem and my monitor (maybe a couple led lights hence the 12v...
![diysolarforum.com](https://www.mobile-solarpower.com/uploads/1/2/9/6/12964626/final-favicon_orig.png)
