frthompson
- May 29, 2021
- 62
Pictured is the system in my travel trailer with my newly built batteries barely visible though the center opening (8 eve 280 AH cells configured as two 12 V batteries), 2 JBD 150 A BMS, and some other Victron equipment. I was testing every thing out and when drawing 200+ amps the battery side of the shunt and two copper bars on the red disconnect in the bottom of the phot get very warm but not hot. At 100 amp draw they are not even warm. The four black wires on the right side of the disconnect are the negative wires from the two BMS. Does this sound normal or OK? I already checked and cleaned all the connections, and no other connections are even warm. Out of sight is my Victron multipluss 3000 and mppt charger.
