mrdavvv
- Jan 14, 2020
- 404
Hello Forum!.
So im going to buy a couple of battery monitors for my banks. Im interested in the ones recommended by Will:
Shunt Based
Hall Sensor
Seems like they can serve the same function, check battery state and measure capacity.
However, what are the considerations for deciding between each one?.
Shunt:
- More accurate probably.
- Can measure charge / discharge (Bidirectional).
- It requires a prob, wich needs more connections (Adding some resistance to the circuit).
Hall
- Gives more data, cheaper.
- Can only measure charge or discharge
- Its cleaner as it doesn't need a "physicall" connection.
Right now im tipping over the Hall side, i dont need very acurate numbes, and im only interested in the SOC and capacity of my batteries. Also would preffer to have less connections in my system.
So, what are your toughs on this?
Shunt Based
Hall Sensor
Shunt:
Hall
