The SM-12 dc output is fully isolated from the dc input.
A linear regulator shares a common ground between input and output.
Isolation is definitely a requirement for the mosfet gate driver supply, which is why there are two separate 12v supplies.
The TL494 can work directly from between 7v and 40v (42v absolute max).
For a 12v or maybe even a 24v system it would work directly from the dc solar input voltage, and would not require an SM-12.
The SM-12 is only required for a 48v system or anything higher than 48v.
Here is the datasheet for the TL494:
https://pdf1.alldatasheet.com/datasheet-pdf/view/5775/MOTOROLA/TL494.html
You will still need to arrange for a 12v isolated dc supply for the mosfet gate driver, and that should be possible.
Also use a suitably rated Shottky diode for the buck regulator.
Twelve volt operation is certainly possible, but it will require some changes from my original circuit.
* Remove PS1 and run the TL494 direct from the solar dc input voltage (as long as that is below 40v max).
* Replace PS2 with a suitable fully isolated 12v supply that will work over your solar input voltage range.
* Use a suitably rated Shottky diode and mosfets.988
Hi (just carrying on from our post on open source mppt's), I've read a couple of times your discussion on this thread & Open Source Microconverter, to understand your design as best as possible, in the hope of making some.
Its been a real learning curve, I have a basic concept of most of it, but chokes, drains, gates were new to me, I'm getting there.
So your present design for your system has 140 volts coming in, 100 volts coming out charging a 96V battery supplied from strings of 1kW banks of four panels ~7.5Amps. (I'm assuming your test exp. matches your home sys.) So I guess the 96v battery supplies your diy inverter that supplies 240v ac to your home wiring. & most of your parts are what you had at hand. Works best with a 30 amp toroidal (light dimmer) choke.
Lots of questions, but I'll limit them now, so as not to take up too much of your time.
Obviously I don't have the knowledge to modify your design, so best to repeat what you have done.
My system is 17 panels TW 415w, voc 38.08, 13A, North facing, 15 degree gable roof mounted, apart from cloud no shading.
Q. So for your 30A choke, is a 1kW string the maximum for your Mppt?
If I had 3 in-series panels = ~114v x 13A =1482w
that would be excessive, so I could only have 2 in series = 988w? Can I easily increase the choke amperage to accommodate 3 panels,1482w ?
Plus my 13 amps are > than your ~7amps, that could be a problem?
Q. You a have a 96v battery, but can I adjust the output to charge a 48v battery?
(On my present small 12v sys. my off grid home is wired for 12v, I plug inverters into this, next to the appliance. I was planning on having a 48v battery & running new 48v lines to new high load appliances (air con. etc) each with a dedicated inverter.)
Cost? I can't imagine how or from what I could salvage the chokes from, which at a glance seems to be the biggest cost.
ebay 2/5pcs 10A Power Filter EMC Common Modes Inductor Wire Choke Ring Inductance US $8.99/ea
Note ring needs to be hy2 iron powder (I think), not sure what these are.
I assume I can put these in series for higher Amps.
(formula @ https://www.electronics-tutorials.ws/inductor/parallel-inductors.html )
ebay
Electric Welder 450V 470uF Aluminum Electrolytic Capacitor Volume 30x50
100% brand new and high quality
AU $6.32 each
Features:
The capacity is measured at around 470uf, which is suitable for welder.
Voltage: 450V
Capacity: About 470uF
Not sure if these are suitable or could be smaller? As a home build I'd like it as robust a reasonable.
I'll stop here, thanks for your time.
