J jleblan1 New Member Joined Jan 18, 2021 Messages 63 Jun 16, 2022 #1 I bought several 22voc panels I want to wire 4 in series . Each panel has a 50v 10a bypass diode. Will I need to up these to a higher volatage to use the panels in a 4s configuration?
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,589 Jun 16, 2022 #2 No The bypass diodes are rated for the intended circuit. Check the panel specs. And, don't exceed them.
