You need to chose diodes with a Vrrm voltage higher than your string Voc so for example if you plan to put 4 panels in series you need a 150 V diode but I'd add some margin on top to be safe so I'd chose a 180 or 200 V diode minimum.
You also need a diode who has a If higher than the Isc current of your panel (9 A). I'd chose a diode with lots of margin, like 3 or 4 times, so a 30 to 40 A diode minimum.
And ideally you want a diode with the lowest Vf possible as it'll limit the losses when it conducts (althought it's not as important as for a blocking diode who always conducts in normal conditions, bypass diodes should only conduct rarely)
So a search result with the values from my example would be
this
Unless you chose a really high spec diode (more expensive...) it'll need some heatsinking, but fortunately not a lot thanks to the high margin on the If and low Vf
Also, don't buy on Ebay, Aliexpress, Amazon, ... they are fake ones 99 % of the time, always buy on a reputable distributor (Mouser, Farnell, Digikey, ...).
