i've read and watched a lot of stuff on charging LiFePo...it seems they don't like extended absorption cycles. my controller will only go down to 120 mins for abosrb.
i have to call CC and see what they say, but would it be advisable to lower the absorption voltage so as not to over charge the batteries? it seems that the absorb amps would just fall off to 0 as the battery reached full any way.
with absorb at 57.6v and float at 55.2v, does this mean that, during the day, when the batteries are full, and loads are being run, that they are being run off the battery until voltage gets to 55v (or whatever recharge level is) and the controller kicks back on? on my old FLA, i believe that in absorb and float, that if the battery only needed 1a but loads needed 10a, the controller would make 11a. i don't see why it wouldn't work the same for the LiFePo, but it's just something i read (for a different controller).
i believe my best settings for now (until i call CC) are:
bulk: 57.6
absorb: 57.6
float 55.2
absorb time: 120 min
recharge voltage: 55 (i'm guessing you want it just under float so if it dips, it goes back into bulk? or do you want more headroom, such as 52v?)
i will eventually look at a different controller, more tailored to LiFePo, but for now, i think i can make this one work.
