GarySaf
This is probably a very beginner planning question, but I'm trying to understand how I might connect breakers for a grid-tie system.
I'm looking at a Sunny Boy 7.7-US with around 8.8 kw of panels (just a plain grid-tie with no backup)
The meter goes to a breaker / disconnect and from there to a main panel on the West side of a barn.
That panel has a 100 amp breaker that goes to a sub panel 200 ft away on the East side of the barn.
There are also 2 other sub panels on the North & South side and I am presuming they are all fed by the main panels but these aren't marked anywhere and are much older panels, so I not a 100% how they are powered.
First question: Can I connect the PV inverter/breaker to the sub panel (the one thats 200 ft away), or do it always have to be at the main panel?
That would just help me plan where to setup the Solar panels (closer to main panel or closer to sub panel)
Second question: If I were to plan on a larger Solar system with 2 x Sunny Boy's, can one Inverter/breaker go to the main panel and the other inverter/breaker go to the sub panel, or would that typically not be allowed for a grid-tie system?
If the inverters both have to connect to the main panel (assuming 240v 40a breakers from each Sunny boy), do they both go below each other at the bottom of the panel or one on the left and one on the right. In some places, i see that both breakers must be on the same side and also read that they should be on opposite sides for balance.
I might have a few more questions, but just preliminary planning/understanding/advice and just making sure I'm understanding correctly.
