My 2 cents. Give up on small wind.I've gone through two 1kw wind turbines (African wind power and a e300 Kestrel) and both have failed after only 2-3 years of use. At this point in time I am wondering if it makes sense for any land based installation to spend money on a mechanical system that is inherently less reliable then a passive system such as photovoltaics. The price for slight increase in number of panels + battery storage seems like would outweigh the hassle of any wind turbine. I assume there must be special cases but otherwise does it make any sense now-a-days?
Like I tell my customers "I know with a very high certainty the solar array we install today will still be churning out KWH 20 years from now, most likely with zero maintenance. With just as much certainty I know the small wind turbine will give you nothing but trouble and be dead within 5 years" That's the end of the conversation.
I have looked a great deal into Missouri Wind and Solar and they seem to be one of the best I have found but more expensive. Much better than any Chinese rice paper fans. They are US made, as far as I can tell, and sound pretty darn rugged and deliver a heap of power. You have a different controller than solar for the power delivered, as it is so variable, but then you can use whatever batteries/inverter you already have. It delivers AC so you can run the cable a long distance with very little drop in voltage. The cable size is a fraction the size you would need with DC. Then inside your place you use a rectifier to convert it to DC and then it is all the same as from solar. These come in 12/24/48 volt units.I would like a wind turbine, but what I want doesn't seem to exist. I think mine is a special case.
I'd like a portable wind turret that can produce at 12 volts between 10 ah and 20 ah a day, or about 10% of my daily use. That is 120 watt hours to 240 watt hours. This would be to get through the few cloudy days better, and perhaps even extend myself to 4 days with no sun.
Places I go would have enough wind between one and four hours a day. If my RV is rocking back and forth due to the wind, I think there's enough to spin a turret. These winds are the on the edge of the desert mountain winds that pick up for between one and four hours between sunset and sunrise. Next to no wind the rest of the time.
I think, if what I say is even possible, would qualify for what you mentioned as a special case. A generator would certainly be easier and exponentially cheaper, but I don't want that.
Having no experience with that situation (no sun for ~5 months) I dare not speak to your best option but I can offer some thoughts.Thanks!
A question, I would be looking for wind that occasionally can fill up my batteries to keep them going 365 days a year (I get no sun from November to March) in my summer cabin. Mostly to keep some web cams going filming the nature, perhaps heating up the batteries a bit.
Do you think it’s hard to even achieve that?
I have been considering putting up a home built turbine that can’t turn pointing either to the North (perfect conditions since on the shore (no salt) and the wind comes directly from the North 15% of the time) or to the South 20% (can also get a good position, but cables must be around 50 meters).
The winter conditions are really tough, but I could basically put a roof on it…
Type "Missouri wind and solar complaints" into your favorite search engine and you will find some people who have tried their products.I have looked a great deal into Missouri Wind and Solar and they seem to be one of the best I have found but more expensive. Much better than any Chinese rice paper fans. They are US made, as far as I can tell, and sound pretty darn rugged and deliver a heap of power. You have a different controller than solar for the power delivered, as it is so variable, but then you can use whatever batteries/inverter you already have. It delivers AC so you can run the cable a long distance with very little drop in voltage. The cable size is a fraction the size you would need with DC. Then inside your place you use a rectifier to convert it to DC and then it is all the same as from solar. These come in 12/24/48 volt units.
I was looking at a system of turbine and controller (with dump load capabilities) at around $2600, but there are cheaper options.
What have others found? Has anyone actually tried any Missouri products??
Cheers
caveat...never watched the video. simply commenting on your post. all turbines have a range of RPM they work best in. Did you know most wind turbine projects that are cancelled are cancelled due to too much wind? yeah... its harder to control the genset in places where the wind gusts for a period of time... only steady state/stable/ laminar airflow is acceptable for commercial projects. think about it a bit.Total Cheap and Absolute Crap!
Thanks for wasting my time watching this video which you must not have watched because he says it made no power in 25mph winds.
They are good but you don't always have good wind. Good add on though for solar."The only small wind turbines that work don't have monitoring".
I stole that quote from a pier who, like me, tried and tried but never installed or even saw a small wind turbine that really ever worked. "Worked" being defined as actually producing anything close to the expected energy (kwh) over the course over at least several years (heck I like to just see one month) verified by actual monitoring which is a much different thing than watching it hit rated watts for a few seconds during a high wind event.
Rambling rant follows.....
Over the last 30 years I've installed or been around pretty much all of them except the old time Jacobs. That list includes (all?) of the "quality" brands like modern Jacobs, Bergey, XZERES, Proven, Kestrel, AWP, Enertech and a few others. I've never installed one right on the ocean coast but but after speaking to some owners the salt environment eats them alive.
Thankfully I only actively installed small wind for less than 3 years and then realized something was up so just started telling people to call someone else. However since my name was out there for many years to come people would still call me to try to save their project. I'm might take look at some but most people already knew they were skunked and just needed a 2nd opinion. Some wanted to me to buy them but I could only respond with "I wouldn't unless I've got already have a buyer who knows exactly what they are getting into"
The names might change but the story never does so here it goes: Within 3 months of installation its pretty clear that we had been told some pretty big lies by the manufacturer. Within 24 months most have been down at least two times for months or longer and now the warranty process clearly isn't worth the hassle to keep them alive any longer. Then there's a few that managed to still be flying after 5 years. Eventually there's ones last failure and the owner has all lost their taste for the turbine spending more time being repaired than in than in the air.
Keep in mind I'm talking about residential scale stuff as in 10KW or below.
I've yet to bump into someone that can make this statement after more than 12 months of actual experience with small wind. Please share the make and model of small wind turbine you are referencing.They are good but you don't always have good wind. Good add on though for solar.
I can’t speak to whatever he meant but the small hand-wound vawts that do milliwatt output can work down to as little as 6mph winds. But that’s milliwatt output! Wind only works where it works- and in northern New England that’s not all the time , for sure. There’s like 14 450’ tall turbines less than a mile from me on a pretty high ridge; they don’t turn all they time.actual experience with small wind
Yaetek and not 12 months try 5 years. And it's still keeping my battery at 13.2 volts. I'm not using it for a inverter or running home electricity. It runs some lights in the work shop and maintains the battery that's as far as I have needed it for now. Now any more than that and I would go on up on the watts with a bigger turbine.I've yet to bump into someone that can make this statement after more than 12 months of actual experience with small wind. Please share the make and model of small wind turbine you are referencing.
it's only a hassle because there is nothing open source yet that actually does what it is designed to do.Personally, I think wind is too much hassle, too much maintenance, too fragile - and noisy. Solar has become so cheap that I don't see the point of putting up a windmill, even if I am not able to use solar here in winter and a wind mill could off-set some of the fuel I use for generator-charging the batteries during these dark months.
That's cool. Wow! $99 and still plugging away! That thing deserves a spot in the secret safe with the 500MPG carburetor.I was lucky on the pipe part my cousin owns his own welding shop. It's on a 30 ft pole do $80 he had some leftover of the 1/2 wall pipe from a boat mourning dock. It's not dependable it's just a hobby for me. I agree solar for serious power is more reliable and a better investment. I did notice the yaetek is not available anymore. Back when I bought it was $99 so I wasn't expecting to much.
hahahhahhaha brilliant"The only small wind turbines that work don't have monitoring".
