chaosnature
- Sep 15, 2022
- 431
I had already started a discussion on another thread but realized it was not the right place to place the discussion so have opened up this thread to complete the discussion
@MrPablo
this is the origianl discussion and what survived the deleted conversation
when i toggle off the Bluetooth - as soon as the ESP loses connection with the BMS it starts discharging immediately, so to me, it has something to do with the ESP side of things.
Also , there is a leak to the Grid of about 200 watt on discharging....
discharge current 20 A set
could any of the settings here help to resolve this?
If so what should be set in my case?
Edit:
Just after i posted the above i toggled on the bluetooth
it stopped discharging ...then a few seconds later starts to charge even though i dont have a charge schedule for this time
it is 19:69 as i type this
i have changed it back to 00:00
this was how it was and i set a discharge bcos it wasnt discharging this evening
ah Penny has dropped for me - i think i know what's going on here
the charging right now is caused by the ForceCharge - so maybe if i set it to 5 - if it will take it then it should not be forcing charge.
But then it means the maths on this is not correct....all of these activities should be taking place near 0% not at 50 %
Right now it has stopped force charging and we are at 18 %
Edit
When i checked all this it was all happening at 5x% - but it seems its actually 18% now, must be a refresh thing between the ESP and the JKBMS
So its actually doing what its suppose to do, but i think it needs a little tweaking
3.5 cell voltage should not be 18 %
The error has to be in the JK Settings
Right now it has stopped charging
My 0% SOC is correct - so again its the ESP not reading my SOC right - 44.8 is when it should read 0%
If 0% is 44.8 what should 18% be ?
Not 49.7x - i think not
Edit
i am thinking its the Capacity that needs adjusting now....
@MrPablo
Edit:
Edit
Edit
