It looks like the battery dropped to approximately 43v, likely 43.4v which is the cutoff now set in the YAML. That happened at about 10:40.
This is essentially empty, hence why the inverter went into force charge mode.
Based on the voltage drop throughout the night, I would say the battery capacity is not enough to cope with overnight house load, then heavy loads such as a kettle, etc, before PV power is coming in.
You can tell that by the rapid drop in voltage, suggesting voltage sag under heavy load.
