Tulex
Solar Wizard
Finally got my system up and running with the first bank of panels. The issue I'm having is that I get an arc fault when that option is on. I can turn it off and get the following readings. This is after 3pm, so not sure what I should expect.
No batteries connected yet, they are on a slow boat from China.
14 Solarever 455 panels = 6370 watts, 2 strings of 7
Actual watts is 3680, did see as high as 4250 ish.
Volts unconnected string 1 is 315, string 2 is 317
Volts connected string 1 is 254, string 2 is 240
Amps string 1 is 7.4 +/7.8-, string 2 is 6.5+/6.8-
