I have a 15k with three arrays of DC PV connected to each of the three MPPT controllers. Each array can max output of 6,400 watts. So that is 19,200. The 15k specs state that it allows 19,500 of PV connected and will invert 15k max.
Here’s the problem- once the panels hit 13,200 that is the maximum and it clips / throttles all day with a perfect flat line. It absolutely will not invert 15k at this point.
Sol-Ark support has been working with us. They have updated software, reapplied update, and performed a full factory reset with no luck. Originally, the inverter would hit about 12k to 13k of PV power and literally disconnect from the grid. During the grid disconnect, we would see completely inaccurate reading of the VoC of the arrays. Voltages that were absolutely untrue. We were also checking with metering equipment and have never seen such a VoC spike. Nonetheless, It seems the software update corrected all of that. Sol-Ark support advised that they had seen some software issues with voltage misreading on the MPPT inputs we were seeing in the software as well as the inverter ramping up the output voltage to the grid too high, causing disconnect. I’ve seen both of these issues. Again, these were corrected not only with a software update, but a full reset of the unit.
As of the final software update and reset on 10-18-2022 we no longer see the grid disconnect. However, we are still seeing the clipping at 13k.
I really believe in the company and we are an installer and we have put in over 20 of the 12k units. However, I could not in good faith sell a 15k until this is addressed on our test unit.
Additionally, we are waiting to connect 19k of AC coupling through the AC coupling input, if Sol-Ark can address the PV DC inverting clipping / throttling issue.
I worry that Sol-Ark never tested this unit fully with the maximum PV specifications that they have published. Is anyone else out there seeing this, if you happen to have enough PV to see it max at 13k?
@Devin
@solark_cooper
@Will Prowse - do you have enough panels to do this same test?
@Devin
@solark_cooper
