Outpost_51
In search of cleaner power while using generator connected to Sol-Ark.
I have a Sol-Ark 5k (3 simpliphi) that I installed myself and currently configured a generator to supply power to the GRID input.
I do not have a switch to run emergency circuits etc. This is not necessary as this (is a tiny) home is completely off-grid and the load is not so large as to need to do this. In fact, the electric water heater will be changed to a smaller one and assisted with a physical solar collector as a booster (someday).
Generator is portable, not dedicated as backup, no auto start. I plug it in on the rare occasion that I will need to top off the batteries after a few cloudy days.
As connected to the GRID input, I'm happy with the way that both the generator and available PV input can supply power to the inverter (providing for the house load) while at the same time providing for the battery charger. I know about charging rates, no warnings needed here. Excellent videos at Simpliphi btw.
Everything works great and I don't need an explanation as to why the inverter follows the frequency of the generator because I know why that is necessary - similar to paralleling generators. But I want to "clean" this up.
My generator "could" be better and does not maintain a perfect speed/frequency and I would rather have cleaner power supplied to the house while I use it.
A good solution might be to buy a better (inverter) generator, I know, but...
I haven't tried configuring the generator to the GEN input and turning on GEN charging.
The question:
If I connect the generator to the GEN input - is it possible to have the supply from the generator used "only" to charge the batteries?
(and there's NO grid...) So what I hope to achieve by doing this is to have the regular "clean" power that is normally output from the Sol-Ark inverter go to the load, while the generator's (not so clean) energy goes "only" to the batteries. (basically- generator to battery, battery to inverter)
Is this configurable? Or will I waste my time trying to make it work?
Thanks.
Mike
The question:
Thanks.
Mike
