melbaylon
- Jun 23, 2021
- 20
I'm trying to figure out why my solar charge controller is randomly restarting. I have a 5 panel series string connected to a 48V 60A solar charge controller. The string of panel's output (voltage, amperage and wattage) all fall under the SCC's specifications.
I have yet to properly ground the panels. But I kinda ruled that out as the cause of the problem because I had because the SCC was not randomly restarting when I only had 3 panels in the string. But I may be wrong. Do you have any suggestion on what I should look into to solve my problem. Thanks!
(The first 3 panels in the picture worked flawlessly with the SCC. I only started to have the random restart problem when the last 2 ones were added to the string.)
