Here is something to consider. What size of wires were initially installed from the roof to where the SCC is? That will determine the amps that can be brought down.
12awg - 20amps - probably two panels in parallel.
10awg - 30amps - probably three panels in parallel.
The other number is the volts on the SCC
Mppt 100/50 or
MPPT 150/45.
So you can probably get one or two more panels in series with a 150v vs a 100v.
The real problem with RV’s is roof space for panels and getting them to fit.
First select the panels that will fit your roof - then before them - select the Solar charge controller that best fits the panels and your goals.
Good Luck!
Mppt 100/50 or
MPPT 150/45.
Good Luck!
