John45
Question: Are the Solar Edge website and app reading properly for your hub inverter?
A couple of months ago, we had a local company install a 6kw solar system including the Solar Edge 6kw fancy "hub" inverter (SE6000H). This may have been the first hub style inverter that the company installed. I requested that the installer give me full homeowner access to the data from the inverter.
Neither the Solar Edge website or app has has ever returned good info for the system. For instance:
1. Looking at the month readout on the website, the red consumption bars often show consumption numbers up around 50 kWh for each day although our prior usage as reported by PG&E has normally run about 13 - 14 kWh. On the same chart, the green Solar Production and the blue Self Consumption bars are always the same length indicating that we're using all the energy we produce. I know this not to be the case since our meter does turn backwards during high solar production and the PG&E website indicates that we're sending energy back to the grid. The app gives the same readings as the website.
2. Moving down to the Export Import graph, only the red import bars are shown and they're reading too high considering the we do have good solar production.
Here's what I'm seeing:
I've tried talking to Solar Edge tech support a few times to little avail. I'm not sure if it's a language problem or if Solar Edge has been working to redo the website and app for the last 2 months.
Hence, my question to the forum. Are the Solar Edge website and app for the hub inverter working properly for you or did my installer somehow not properly setup the inverter on installation?
