SurfTech57
- Feb 26, 2022
- 2
Error Code 2x99 HW error is Displayed and inverter is rebooting in a loop, VDC Voltage from Panel array reads 435 volts. When systems was in production Voltage was 335VDC.
Did contact Solar Edge and have Case# opened. Bad inverter or Optimizers? When Inverter power switch is Off the Display reads 14.1 VDC. Saw info that the Voltage should be 1VDC with switch Off. Am not familiar with the Inverter. Am helping a Friend out. Thanks for any Feedback.
This is a Grid Tied system with Export.
