Well, I didn’t expect such a response…I’m new to this forum and am impressed. My intro post I kept short, but now that you’ve asked, here goes.
I have a 44’ Sea Ray motor yacht, no sails, room for three unshaded, large (residential size) solar panels (so maybe 1200 W), lots of room for battery size and weight when I remove the 450 lbs, 30” x 30” x 25” diesel generator. Yes, I could replace the generator with a smaller (5.5KW) unit, but I thought I would explore solar generation.
Before I detail the electrical loads I would need, let me first explain my application and likely use. We coastal cruise with our yacht, and most times we overnight in a marina, so we use shore power, no problem. When we are motoring, the twin Caterpiller diesel engines with their alternators generate more than enough energy to power our fridge and other small peripherals (WiFi router, electric fans) that run on AC power (I use a 3000W 12V-120V inverter, yeah, overkill). The real need I require is the occasional night that we spend at anchor or on a mooring, rarely if ever two nights. So I am really seeking advice on powering my AC needs for 12 hours (late afternoon to morning).
I have clamp-metered my potential AC loads during the overnight stay. NOTE: I have three air conditioning units, but I would only run the lower capacity unit for an hour or so, and only if absolutely necessary.
3/4 size fridge - 5 A (600W) Duration on = 5 hours
Two Cabin fans - 1 A (120W x 2 = 240W) Duration on = 4 hours
Two LED lights - 1 A (120W x 2 = 240W) Duration on = 4 hours
Microwave - 14 A (1680W) Duration on = 1/6th of an hour)
Cooktop - 10 A (1200W) Duration on = 1/4 of an hour
WiFi router - 1 A (120W) Duration on = 4 hours)
Salon Air conditioner - 14 A (1680W) Duration = zero!
Front cabin Air conditioner - 7 A (840W) Duration on = 0.5 hour
Aft cabin Air conditioner - 7 A (840W) Duration on = 0.5 hour
(An alternative to Air conditioning might be a dehumidifier + fans)
All the rest of the systems operate off DC from a hefty house battery bank (4 x 100 Ahr flooded batteries)
My current thoughts are to go with a 24V system, 3 400W panels in series on aft cabin roof, a Growatt “all-in-one” solar controller, inverter, charger (about 3000W capacity), and 24V lithium iron phosphate batteries (either true 24V batteries or series 12V batteries) … how much will I need is what I’m hoping you’ll help me decide, if I make this jump from diesel generator to solar generator. I think it makes sense, given my limited need for AC power at anchor/mooring. Also, the cost for a solar generator would be 1/3 that of a diesel generator, and much easier to install.
OK, probably TMI, but I thought I would lay it all out for discussion. Thanks!
