Here is a link to a handy voltage drop calculator that I use.
This free voltage drop calculator estimates the voltage drop of an electrical circuit based on the wire size, distance, and anticipated load current.
www.calculator.net
Plugging in your specifications, I see this.....
It appears that you are only loosing 1V at that distance, which is probably OK until you get your MPPT controller. Then you can wire more panels in series to reduce voltage drop more.
Keep in mind that the better controllers have higher voltage limits, so If you can stomach the extra money, a higher quality controller with a 200V limit (Epever 5420AN) will allow you to run strings of up to 4 grid-tie panels for hundreds of feet. Right now, I'm funneling 8A through 10 gauge wire at 120VDC for 130' without any measureable voltage drop. Then you'll have the liberty to place your arrays just about anywhere you want, which is likely to increase overall production even more.
