INVERTER PANEL
GS8048A-01 Inverter/charger 8.0kw, 48 VDC Flex power Radian AFCI, pre-wired GSLC with 120/240 VAC Bypass, 175 Amp DC breakers, 125 Amp charge controller breakers, 80 Amp PV breakers, MATE3s, HUB 10.3, FN-DC, RTS, plus one Flexmax 100 AFCI Charge control
BATTERY SYSTEM
Also included Midnight Solar MNPV6 disconnecting array combiner. 6 Circuit rated for both AC and DC. For use with up to three 300 VDC breakers or up to six AC breakers. 5.5 pounds. 13.5’x9’x7.25’.
Midnight Solar surge protector for DC circuits. Rated for 300 volts DC nominal and 250 volts AC nominal.
This 1/2 in 1000V Heyco Strain Relief accepts two 6mm PV wires. Nuts included.
FIreRaptor Rapid Shutdown Unit - suitable for connection to two solar panels.
Emergency Rapid Shutdown Switch IP66 (for FRS -01) - includes 24VDC power supply.
1.8m (70?) Signal Cable terminated at one end with Tyco female connector for use at end of PV String.
Midnight Solar High Voltage circuit breaker, 15 amps, 300VDC
Asking price:$8,000
BATTERY SYSTEM
Asking price:$8,000
