YahwehisKing
- Mar 5, 2022
- 25
Oooooooohhhkkk
Got a little shit stew to brew... lol
I currently have a solar array of 5s3p made with renogy 100watt panels. I just received 6 240 panels.
All renogy panels are model 100D SS
Though the most recent string of 5 have different stats than the other 2 strings.
Stats are as followed
2 strings of renogy 100DSS
@ VOC 21.6
VMP 17.9
IMP 5.72
1 string of renogy 100DSS
@ VOC 24.3
VMP 20.4
IMP 4.91
The panels I want to add are
Sharp 240watt(brand)
@ VOC 37.4
VMP 30.1
IMP 7.96
Also note I'm using a growatt 48v with a max voc input of 145v and a starting charge voltage of 60v
I was thinking of doing the 5s3p con fig and then config the sharp panels in 2s3p and connect it all parallel, would I write that as 5s2s6p lol
The voc for the 240 watt panels would be 74.8 at100% eff but that would bring down the 5s configs to 3/5th eff right??
So would I wire the sharp panels in a 3s to make the voc 112.2v matching closer to the 108.2v of the 2 5s strings and 121.5 of the other 5s string. If the VOC is similar does it matter that the 3s string of 240 would be 720watts when the 5s string is only 500?????
Thankyou for any help offered
@ VOC 21.6
VMP 17.9
IMP 5.72
@ VOC 24.3
VMP 20.4
IMP 4.91
@ VOC 37.4
VMP 30.1
IMP 7.96
