Jinko solar panel has a 4mm hole in its frame for grounding wire connection. Which size bolt should i use for it? M4 or M3? I read somewhere that M4 means 4mm is hole size and bolt diameter is smaller than 4mm, other sites say that M4 bolt means 4mm diameter and it requires a 4.3+ mm hole size. Can anyone confirm which one is true?
