Stick with six panels as a meaningful start! Have always two connected in series, they then usually called strings. So you'll have three strings of two panels in series each. For best performance, you can orient one string facing dead south, one string facing more towards east and one more towards west. That way you flatten your mid-day peak and earn more in the mornings and evenings. It's also easier on your batteries and inverter as the peak charging current is slightly less.
Not bad advice, but know that when you split an array up like this, your peak harvest will be decreased vs. a single array optimally positioned.
Having multiple arrays opportunistically positioned is most effective when your total solar is greater than your SCC can handle, but orientation ensures they do not exceed the total.
Example.
3X 2S3P arrays (2640W each)...
1 in a ESE orientation
1 in an optimal Southern orientation
1 in a WSW orientation
One can simulate each array individually using link #6 in my signature. You can download hourly data and then combine them.
