JWLV
- May 27, 2020
- 551
I have 18 solar panels that I bought from Santan Solar. These are used panels which Santan says are 240W. I believe they are relabeled Trina panels.
I have these panels tilted at 10-degrees, which is ideal for my location at this time of year (July 23) to get maximum sunlight.
So far, the most power I'm seeing is around 2700 watts. With 18 of these 240 watt panels, the theoretical maximum power is 4320 watts. The difference is 1620 watts. I'm getting almost 38% less than the maximum. That seems to be rather a large difference. Does this loss seem correct given the environmental details below? What do you guys think?
Environmental details:
The panels are not in any shade or near any trees.
Each string is 3-panels in series. Total of 6 strings. 3 strings connected to one combiner box to a Growatt SPF 3000. The other 3 strings connected to another combiner box to a second Growatt SPF 3000.
Both Growatts are connected in parallel to 22KHW of LiFePo4 batteris.
The time of the measurement readings is between 11am-1pm.
The weather at the time of the measurement readings is extremely hot, around 110 F air temperature. The panels are much too hot to touch. I estimate the surface of the panels are at least 150 F.
