We just had a solar panel install in the United Kingdom (latitude of 57 degrees). The panels are installed on a flat roof at an angle of 10 degrees (i.e. nearly flat). I was expecting an angle of 35 degrees for maximum efficiency, but the contractor claims that a 10 degree angle is standard for a flat roof install.
I know that the panels will harvest less energy because of the smaller angle. My questions are:
- Is the contractor's information accurate (or did he just buy the wrong fittings ...)?
- Is the difference in capacity substantive?
