I was able to see both batteries together. I used the HUB mode. please see attachment.
one question, when can I connect them in parallel and make them as a battery bank? currently they have a slightly different state of charge and voltage… charge them full first?
I don’t have a Lithium charger to charge them from AC , shore power. I have DC-DC Renogy chargers ( 40A and 60A ) and 2x Rover 60A MPPTs. I guess I can charge them with solar..
I have the 3000w renogy inverter… what thick / rated cable I need to use between the batteries? They are 20-30 cm from each other.. side by side.
I wanna use kitchen appliances, washing machine over the inverter. I guess I will pull 50-100 Amps from the batteries in normal use and possibly 150-200 amps when using the washing machine.
are the cables came with the inverter good enough for these amps? Inverter will also be next to the batteries.. 20-30 cm away.
