offgrid22
Hello to all, I AM new here and even less than new at what I am attempting, I have a small 48v solar set up with 2500w of solar and about a 20K battery bank. I AM using a 6K inverter with built in charge controller. I would like to tie in a small wind turbine for winter use since I get less sun. My question is, will there be a problem connecting the 48v from the turbines controller to my battery bank? I plan on having disconnect switches on bothe the solar coming in and the turbine voltage coming in. So they will never be on at the same time. Will the voltage going to the batteries cause any issues with my inverter? Hope my concern is understood, looking forward to responses and or solutions. Thank you
