K-fab
My largest cost in my shop is the A/C system. Being that I'm generally in it during daylight I'm thinking that if I can remove the highest energy eater and convert it to solar I can drop my electrical bill quite dramatically (probably pay for the system in less than a year).
Present idea is to power the two A/C systems (both 220V on 30A circuits - no, I've not climbed up on the roof and actually looked at wattage requirements of each unit, that's my next step to size accordingly) via solar as long as there's sufficient output from the PV panels. I'm in central AZ so lack of sun isn't much of an issue often.
The basics are pretty straight forward and I have a pretty good understanding of what I need to set this up but here's the caveat - I'd like this setup to switch back to public utility powered when the PV setup can't keep up (which should only be when the sun's not providing enough light to the PVs).
Does something like the Growatt or EG4 have the ability to switch load control? I want this to be stand alone and NOT feed back into the grid therefore the units would be set up on their own separate circuits and I was originally thinking a manual selector switch but is there a switch out there that can be programmed to do this? - is that something that either the Growatt or EG4 can do?
I know, newbie question. Hopefully someone can chime in (without telling me to search - I have, probably not to everyone's satisfaction). We all start at the beginning and I'm standing here at the door to that world.
Thanks in advance.
Thanks in advance.
