svetz
Works in theory! Practice? That's something else
A continuation of the topic out of the Traffic powered wind turbines thread so as to not derail that thread further.
Warning: A topic not for the faint of heart as most of the vocal community believes this is a stupid idea, so if you post a strong opinion you'll be most likely be challenged. Please be respectful and don't get yourself banned.
Some of the Solar Road disbelief seems to stem from this youtube shock-jock:
But, when you take other factors into consideration, the economics of putting them into the road might make sense. The factors that come to mind are:
Should they cancel it? Heck no, can't advance technology without trials.
He's made a number of videos about how stupid they are. Much of that assertion is based on a comparison that maximizes watts by putting panels on a rooftop at the proper angle rather than flat on a road that cars/trucks drive over. And that's true! But it also assumes that rooftops are available or that weather conditions allow over-road/canal placement. It also doesn't consider the costs of roads or how embedding solar into them affects the costs. Adding solar to a road may offset the cost of the road to the point where it is more economical to build solar roads. |
- Cost estimates to build a solar road at $1/sqft with mature technology versus current road costs of $3/sqft (largely due to increasing costs for asphalt and concrete, synthetic roads are coming regardless as to whether they're solar or not).
- Roads typically have power lines running along with them, making grid access easy.
- Even at reduced power output due to an inefficient tilt, at southern latitudes, they are still more cost-effective than natural gas and produce less CO₂.
- From the standpoint he's just having fun and entertaining people it's fine. What's wrong is it's misleading and it's harder for technologies to advance and be trialed if public opinion is against them. AFAIK, Solar Roads are not a mature technology ready to be deployed. But I do believe the economics are interesting enough to warrant small projects (like Spain's) to help advance the technology. Even if solar roads don't work out, they will still advance composite roads.
- He makes a big deal about it, but the expected STC energy rating is only 10% less than roof-top panels (2:40) at no-tilt.
- It's only 9 kW because it's a test array. That's a good size for a test IMO.
- At the end of 6 months, it's supposed to be dug up and analyzed. It's an experiment designed to further the science to see if the technology can be made practical. It's an investment.
- "1/3rd the output for 9x the cost", which was a trial in France and compares to roof-top costs rather than road-construction costs.
- He says the cost is far greater at 30K euros than a rooftop array, but in USD that's $36,600 for the equivalent of 9kW array, or $3.66/W which is only about 50¢/w over what you'd pay for rooftop solar In my HVHZ area, and you get a road - so might be a bargain.
- "We have results from everywhere else!" Not really, all of those are test trials with different materials, each generation hopefully better than the last. If we gave up after the first failure then we wouldn't have lightbulbs, footsteps on the moon, flight, etc.
- "It doesn't matter how mature the technology is" - this is primarily based on laying panels flat. Yes, you take an energy hit by not optimizing tilt. But, that's not as big of an impact closer to the equator. Even at the 15% loss in Sydney, it's still has a lower cost than natural gas. It also doesn't consider the cost of the road.
