Hello.
My name is Bogdan. I’m the owner of a solar tracker, diy made but not by me.
Yesterday I had a problem, today same problem. The problem is, at local hour 12:45-12:50 it went to the north that much that fuse was disconnected, yesterday i was at home, i even try to put in protection mode and barely i got it somehow stopped and later i reseted it and worked as normal. Today seems to had the same issue as I found the fuse down and facing north at maximum. I don’t know where to check and what to check as after this hours seems to work ok, and the person who did it dosen’t answer the phone seems.
Any help will be highly apreciated.
Thank you
Thank you
