I've been trying since solstice to get a good sunny day and an available laptop to set up the oscilloscope to compare the two arrays.
Today was that day!
I have two identical arrays of 480 watt Q cell bifacial panels. Both are 2 in series paralleled into the same Midnite Classic 150 charge controller.
I am out of south facing roof, so I have 1 pair facing due east on my 4/12 roof (about 20°) (green trace)
The second pair is on the solar tracker (red trace)
The vertical lines every minute are the tracking doing a sweep. I turned the tracker from "PV" to "dynamic" for about 50 minutes while I looked up the options in the Midnite manual. PV is recommended and they don't detail dynamic very much. You can see the sweeps stop while in "dynamic" mode.
Green is roof mounted, facing due east 20° pitch
Red is dual axis tracker.
The vertical cursors mark when a hard shadow clears in the morning and when a soft shadow starts onto the panels in the evening. I probably lost an hour of good production due to that trampoline net.
A few clouds rolled through about an hour before that causing the drop and spike, otherwise it was sunny all day.
Here is the same graph plus voltage in blue
Panel specs:
The tracker mounted panels outperformed the IMP both STC and NOTC.
The east facing panels peaked at about 50% of IMP.
However voltage was below VMP (50.56 x 2) nearly all day. I don't know what to make of that.
This says to me the tracker is performing well. I'd probably need 4-6 more flat mounted panels (which I might not have room for even using both east and west roof faces)
I'll try and do this again in the spring or summer to see how the two arrays perform with more sun.
Oh, and for those curious, here's a tracking cycle with some markers:
