I purchased during the black friday deals an Eco Worthy Dual axis solar Tracker. In researching it I thought with a couple of updates it might be able to accept higher watt panels. First would be a change of actuators from the standard 330lb to a 660lb actuator. https://www.amazon.com/dp/B0BZP9JN3...CF1F2C06849EA84051C230B795EFC9D762D85341&th=1
They can be had in different lengths. The question before my “panel of experts” as my wife calls you is; would changing the actuators actually allow for heavier, higher watt panels. I am thinking 6 Longi 600w panels.
This would also be raised on a 3”(?) steel pipe to reach above roof line. I figure I would have to have a pipe long enough to be buried 6’(?) in concrete To accommodate the weight of the panels. I have a small lot that the house sits on and do not want to do roof mount. Your thoughts, ideas are appreciated.
