According to the data I found they have an open circuit voltage of 36.9 volts and MC4 connectors so they should work. Your 40 amp controller has a voltage limit of 100 volts so three of those panels would be too much in a series, but two should work okay. I add 4 volts for better efficiency in cold climates so 36.9+4=40.9 40.9x2 panels=81.8 volts open circuit. If you are going to try to parallel them with your Renogy panels I'm not sure about that set up.
