I will take it. That's exactly what I was looking for. Let me know how you want to proceed with payment and shipping. I'm in AZ.Hi, I have one brand new, never used, never opened, still in original box, Victron Smartsolar MPPT RS 450/100 for sale. Reason I am selling it is because I really needed the bigger 450/200, so now this one is not going to be used. All yours for $850 and I'll pay ground shipping (UPS).
Wow, great deal, I have the 450/200 and was about to scoop that..... well done Chris (I'm also in AZ).
Awsome!! It is also nice to see some fellow Arizonians on this thread.All yours Chris! Sorry everyone else, only have one.
Hi - I was wondering about the 450/200 vs 450/100 and wanted to see what the reasons for picking to 200 would be over the 100?
Trying to understand the different Victron components better and is it mainly, so you can charge / invert at 200amps?
Or, is it more useful to be able to output mores amps from your solar panels? I was thinking that you'd want to get enough panels in series / parallel to try and get to 450 but keep the amps low so you can use smaller gauge cable.
Also, I don't quite understand why 2 x 450/100's wouldn't be better than 1 x 450/200?
Would really appreciate any insight on what one might pick one or the other option.
Welcome to the madness of solar and tons of component that do maddingly similar things.Hi - I was wondering about the 450/200 vs 450/100 and wanted to see what the reasons for picking to 200 would be over the 100?
450/100 = 100 amp and you can have 2 independent strings. Maximum DC output charging powerHi - I was wondering about the 450/200 vs 450/100 and wanted to see what the reasons for picking to 200 would be over the 100? Also, I don't quite understand why 2 x 450/100's wouldn't be better than 1 x 450/200?
Very true - I see now the appeal of things like the Sol Ark 15k, which was what I was leaning toward initially.Welcome to the madness of solar and tons of component that do maddingly similar things.
That is such a great reply - thank you.450/100 = 100 amp and you can have 2 independent strings. Maximum DC output charging power
4000 W per tracker, 5760 W total.
450-200 = 200 amp and you can have 4 independent strings. Maximum DC output charging power
4000 W per tracker, 11520 W total.
So to answer your question, 2 450/100's would give you 4 strings, a single 450/200 gives you the same amount with less DC cabling, less cost, less install, less VE.can cabling, less weight on your wall (7.9 kg vs 13.7 kg).
The more important thing to ask yourself is if you REALLY need a 450 in either flavor. These are meant for installations of multi panel high voltage arrays, which is what I have and the 250/100 I had just wasn't sufficient. Also the 4 independent trackers allow me to run different panel configurations on the various sides of the garage they're mounted on without impacting each other. The South, SE, SW and flat against the wall facing SE for winter and snow load.
Compared to the other lower string voltage SCC's like the 250/60, the voltage start and operating range of the 450/100 and the 250 are vastly different. The 250 will start tracking from 5v above the battery. The 450 will not do this, again, it is designed for high string voltages. The 450 will only start operating at 120v and can use the range 80v to between 400v and 450v depending on your battery float voltage etc. But the algorithm is also affected by battery voltage. See the tech spec section of the manual. You need a higher string voltage to make the 450 work to it's fullest potential.
Buy once, cry once, trust me, and others here will back up the following statement, "Buy for what you WILL deploy, not for what you ARE deploying now" this is addictive and if you can (with your current system) deal with the need for high string voltage before battery charging starts that the 450's require, they're a GREAT investment for the future.... if not, we look forward to seeing your current SCC in the classifieds section once you realize how cool this is and start ordering pallets of panels. ?
Jen
Thank you for the great response, that makes me feel good that it helped you, so often we help people here and are not really told that it helped or was appreciated, your post warmed my heart.Very true - I see now the appeal of things like the Sol Ark 15k, which was what I was leaning toward initially.
You've explained that so perfectly. While, i'm new to planning solar for my property and been reading quite a bit, this helped really in understanding the charge controllers and specifically the rationale for the 450/200.
My whole project is going to end up being fairly large and for now, I'm working to figure out the sizing and specs to help submit by CA Nem 2 application prior to April (https://diysolarforum.com/threads/solar-design-planning-northern-california.54952/) and then actually complete in the next 2 years.
If you care to read the post above I created last week, you'll see what my initial concerns with the sizing and annual usage were and based on this initial leaning toward the Sol Ark 15k's, but I would need at least 2 ($16,500) and i'm reconsidering the equipment choices now and trying to learn a bit more about Victron.
Thank you so much, that was really a great way to simplify that portion for me.
I would 2nd this. Higher voltage strings have a lot benefits in my experience.That said, you’ll be amazed how easy it is to go higher in voltage without knowing it and than most charge controllers can handle. Panels now are really improving and it doesn’t take many to get over 250v in a string,
