They should have, yes. But they didn't. I'm going to email them again to see if they can get one to me.The Solis is supplied with both connectors, so your installers should have left you the unused connector.
Surely, the AC-backup is just the opposite sex version of the AC-grid connector? ? Mine looked like that when I installed it.
So, maybe this one?? https://uk.rs-online.com/web/p/lighting-connectors/5131884
Good point, although @rpdom said he had "2x Pylontech US2000 batteries" from another thread.Without a battery connected, the backup port will not be powered, keep this in mind before spending $$ for the connector
I asked the company that installed my inverter and they are sending me the connector. With the threat of power cuts looming this winter I'mhoping to get my lighting circuits and a few essentials hooked up to it instead of to the main circuits.
I was assuming that if the batteries get too low to run the backup they will force charge from the grid - as long as the grid is still up. If the grid is down as well, well I'm stuffed either way.Good point, although @rpdom said he had "2x Pylontech US2000 batteries" from another thread.
What is important to know, though, is that when that 4.8kWh of battery is used up and there is no sun, the backup port will power down. So, by all means use the backup as an alternative, but not instead, as you indicated below...
Sorry - was having a blonde moment - yes, the batteries will stop discharging to power the house when they reach the overdischarge limit, but will keep powering the Solis, so the backup port will still run. Only if they get to the force-charge limit will they draw from the grid. Ignore what I said above ?I was assuming that if the batteries get too low to run the backup they will force charge from the grid - as long as the grid is still up. If the grid is down as well, well I'm stuffed either way.
Your idea of moving your lighting and some essentials circuits from your main CU to an essentials CU fed from the AC Backup port is a good one and is exactly the purpose of the AC Backup output. Mine is wired that way with a changeover switch though. In the event of an inverter failure I can change over to grid which would then directly supply my essentials CU.I was assuming that if the batteries get too low to run the backup they will force charge from the grid - as long as the grid is still up. If the grid is down as well, well I'm stuffed either way.
Not good that you have that many grid-failures, but good to know that this backup feature works well with the Solis.We have grid failures up to three times a day for pre-defined periods and as long as the sun is doing its thing my batteries aren't used at all. PV essentially powers my essential loads.
Not good at all. A sad sad state our country is currently in. 15 years of what we call 'loadshedding' which is a direct result of government corruption. Oh well, can't possibly get any worse. Oh wait...I'm sure it will ?Not good that you have that many grid-failures, but good to know that this backup feature works well with the Solis.
Indeed, and thank you both for confirming that the AC Backup output will do what I want.Not good that you have that many grid-failures, but good to know that this backup feature works well with the Solis.
I might increase the overdischarge limit to 25% or 30% instead of 20%, to keep an extra 5-10% in reserve for backup.Sorry - was having a blonde moment - yes, the batteries will stop discharging to power the house when they reach the overdischarge limit, but will keep powering the Solis, so the backup port will still run. Only if they get to the force-charge limit will they draw from the grid. Ignore what I said above ?
