awatchfuli
Hi
I'm a 1yr old to solar and purchased a Victron MPPT 450 100 charge controller to give my 2 EG4 6500ex @ 240v a break as a charge controllers.
They are very happy now just producing power.
Problem:
I have 3 panels (see attached pic) specs connected in series and connected to PV2 on the MPPT. It showing 103v with NO amps and NO watts coming in.
Tested each panel and the Voc was correct. Checked all the connections and they were tight. Read somewhere about diodes failing. Opened the junction boxes on each panel and they were filled with rubber so no access. Reconnected array to one 6500ex and the panels show the same reading so it's not the MPPT.
Q:
What is causing this and how can it be fixed?
Appreciate your response...
Thanks
Problem:
Q:
Thanks
