linuxdrake
Solar Beginner - Electrician / Hardware Engineer
UPDATE: FIXED See Last post, DIP switches not like manual for SOME units in 2-way parallel..
Having an issue attempting to parallel 2 15K's together. Both have a common battery, grid and load connections.
The master unit has the Batteries connected 12x EG4-LL in Closed loop and no issues with it reading them.
Additionally the master unit has the 2 CT's connected and Gen 2-wire start.
Prior to paralleling I did have the firmware updated on both units, so they are on latest: 7.2.2.2
I tried paralleling them with the enclosed yellow CAT5 cable from Sol-Ark, but also with my own 5' Shielded CAT6, which tested on my fluke perfectly, both did in fact.
Set them up per manual, using Master ModBUS:1 and Slave on ModBUS:2 both on phase A.
Powered up/down via manual, and no dice. I occasionally get the F29 - Parallel_CANBus_Fault when I reboot the units, but not again.
Any thoughts? I have left 2 VM's with Sol-Ark but no return call for over 3hrs now.
Side Note:
To validate everything is working I placed them into grid sell only mode, and both are working individually charging the battery up at the moment.
Side Note:
