dougbert
Alright. I am fidgeting waiting for the XW Pro to get here, so.....
some minor updates to the AC side schematic diagram
Forward reference to the schematic in Post #1
One major addition is a 2nd range/oven recepticle from the main CLP to the wall behind the oven in the kitchen (directly above this area). This is inflight at the moment while waiting for parts, This will provide 2 seperate 4 plug outlets - one from the grid and one from the CLP
When I started to add this 2nd outlet, I discovered the range has a 3 plug cord. In 1996 the NEC started requiring 4 plug cording for ranges in new construction. As this house was being remodeled back in 1995 time frame, the 3 plug recepticle was installedl. How a 3 plug works is, it provides the two legs, L1 and L2 and a Neutral - but a jumper between the Neutral and the chassis ground of the oven. EGADS! As this unit did NOT have that jumper installed
So I quickly ordered a new 4 plug cord, box and will adjust the existing grid recepticle. Got a 10 ft section of 6/3 romex for $55 off off ebay and adding that now
Something I built DIY back in 2000 - my path from Trace to Xantrex to XW Pro inverters
2023-09-21 Version Update When I started this thread back in 2019, I did not realize it would turn into a build thread of my system. It documents What and Why I did things as well has How they were accomplished. It also shows designs that didn't work out, and also designs that did work out...
diysolarforum.com
